17 years agoGrounding recommendations
Hello. I am using the Cyclone III FPGA starter board and a Terasic THDB-HTG breakout board for interfacing to my circuit. I would like to know what is the recommended way to ground this board. My ...
17 years agoBefore you power anything up, just measure make sure the two ground planes (your circuit and the dev board) are truly at the same potential. Otherwise, I foresee smoke and a little hole in that little Cyclone III.
Is your circuit going to be powered seperate from the dev board? That presents a different set of problems. Jake
