SKacc
6 years agoGeneral I/O clarifications
Hi Please clarify the following queries 1. Does DIFFIO_TX_[B,T][#:#]p or DIFFIO_TX_[B,T][#:#]p acts as input? 2. Does DIFFIO_RX_[B,T][#:#]p or DIFFIO_RX_[B,T][#:#]n acts as output? 3. Does DIFFIO...
AnandRaj_S_Intel
6 years agoHi,
- CLK-P/N is Dedicated positive and negative clock input pins. if you use it as a ordinary/output pin it will not use dedicated rooting.
Also, Since CLK-P/N are dedicated clock input pins, does it impact if I use it as normal differential IO?
No.
Reagrds
Anand
