SKacc
6 years agoGeneral I/O clarifications
Hi Please clarify the following queries 1. Does DIFFIO_TX_[B,T][#:#]p or DIFFIO_TX_[B,T][#:#]p acts as input? 2. Does DIFFIO_RX_[B,T][#:#]p or DIFFIO_RX_[B,T][#:#]n acts as output? 3. Does DIFFIO...
AnandRaj_S_Intel
6 years agoHi,
In this case Clk13p is used as a ordinary output pin.Which will result in Quartus using up ordinary routing resources, whose delay will change each time you run your design through Quartus.
When we use dedicated pin for output, we achieve fast routing, so that the delay to these pins is minimized.
Anand
SKacc
6 years agoHi Anand
I didn't understand. Can you please rephrase?
Also, Since CLK-P/N are dedicated clock input pins, does it impact if I use it as normal differential IO?
Srikanth Kacchu
