16 years agoFrame reader initialization
Hello, I know there is already a lot on the forum about the Frame reader from the VIP suite, but I still don't get it running. I used the memtest software example to test the DDR Ram module of...
16 years agoHi Hans,
I added the TPG again and deactivated the FR. Worked here right without touching anything else. Setup and Hold timings are ok, rest is violated. I have only the clocks constrained. When I add the FR again and connect to the CVO it does not work, but the flicker is still there. So if you like try to step into your idea, I will first try to get out of the system what he is transmitting in the first frame. We will see...
