16 years agoFrame reader initialization
Hello, I know there is already a lot on the forum about the Frame reader from the VIP suite, but I still don't get it running. I used the memtest software example to test the DDR Ram module of...
16 years agoI do not have the time right now, to look into the example, but I tried this yersterday at my testing.
I have attached a picture of the modifications I made to the SOPC-system. I added a FrameBuffer, which I configured to use the same read burst and master bit width to access the DDR SDRAM in the design as your FrameReader. As I run this system on the neek it worked quite fine and gave me the testpattern. I had also configured the FrameBuffer to not add or throw away frames, so normally if the stream would have run out of the specification I expected the LCD image to be altered, too. I am curious what you get out of the project when you carry over the design from the example you found.
