FPGA MAX10 Configuring Failure
Hi MHASI2,
The CONF_DONE pin did not go HIGH (ERROR ID:209014) can be caused by one of the below situations:
1. Download cables not securely connected (JTAG pins)
2. No power to target system (FPGA power issue)
For this, maybe you can re-check your JTAG pins connections (TMS, TCK, TDI, TDO) on board B. I afraid there is some SI issue/voltage overshoot issue.
And one more thing, did you included diode & capacitor as below (as recommended in MAX 10 User Guide) on board B?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf#page=35
For this, can you re-check your FPGA power again (VCC, VCCIO, VCCA & etc2).
Cheers
