17 years agoFlash two or three user firmware into the flash for Stratix II EP2S60 DSP Board
Hi, all I'm using Stratix II EP2S60 DSP Development Board for my project. The reference manual tells me that it can store three user's firmware in the flash for bootload controller by the Board...
17 years agoIf you use the NIOS-II IDE to program your flash device, there is an option to let you program an extra file into your flash. After you tick this option, you can select your file to be programmed, flash device and the offset. This is the simplest way. Otherwise, I think that you have to write or re-write your own Linux shell scripts to do that.
