16 years agoFlash programming issue with stratix kit development
Hi, I have a stratix3 development kit. Flash: 64 Mo Max II Stratix3 FPGA USB blaster I have designed a system with SOPC builder to execute the "web server" application on it. I want to stock th...
16 years agoHi,
Thank you for your answer. Rotary switch are OK. Indeed, I can stock FPGA configuration file in the flash memory by the mean of Quartus plus a design included in the design kit "stratixIII_3sl150_dev_pfl" (flow is described in documentation entitled : Programming the flash device). I think your second sugestion is the right. Indeed, I want to stock all these files. I am a beginner in digital electronic ( I'm working in analog electronic). So could you explain me why is not going to work please ? For my part I 'm going to read again the documentation. Best regards, Jeremy.
