FN0001
6 years agoFlash Loader IP not loaded on device 1?
Hello, I have a Cyclone IV based FPGA board (LimeSDR-PCIe v1.3) I am trying to flash FPGA FW but in Quartus I always get this error. "Flash loader IP not loaded on device 1" see log below. /altera_...
NurAiman_M_Intel
6 years agoHi,
Is there any update on this request? Else, I will continue to close this case
Thank you.
Aiman
- WFitt5 years ago
I have the same problem with programming Cyclone 10 (10CL025Y).
I try to program a JIC file via Altera USB-Blaster. The error message "Flash Loader IP not loaded on device 1" appears. The SOF file is getting programmed well.
I generated the JIC-File with the Quartus tool "Converting Programming Files".
Has anyone an idea?
Wolfram
- MarcoWu5 years ago
Please try to change the code of FPGA to the same JIC file. Then you can program the flash without problem.
- WFitt5 years ago
Hi MarcoWu,
Thank you for your hint!
But I solved the problem yet: The FPGA was held in reset. An other error message like "FPGA in reset, no access possible" would have been very helpful ;-).
