FN0001
6 years agoFlash Loader IP not loaded on device 1?
Hello, I have a Cyclone IV based FPGA board (LimeSDR-PCIe v1.3) I am trying to flash FPGA FW but in Quartus I always get this error. "Flash loader IP not loaded on device 1" see log below. /altera_...
FN0001
6 years agoHi Aiman,
Thank you for your reply. Itrei I have two such development boards and the issue always happens on one of those and occasionally on the other. I do the following steps for programming.
- Open programmer in Quartus.
- Select USB-Blaster in Hardware tab
- Select Auto Detect.
- Select change file and choose the corresponding myfile.jic
- New design opens up. I check both boxes on Program/Configure (For FPGA and EPCS64 flash).
- Click on Start.
- The procedure halts at 21% with the message "Flash loader IP not loaded on device 1"
With the above procedure after checking the Program/configure box a Factory default SFL file is selected to be loaded. Is there any other extra step I should do?
Following are the screen shots.
