FN0001
6 years agoFlash Loader IP not loaded on device 1?
Hello, I have a Cyclone IV based FPGA board (LimeSDR-PCIe v1.3) I am trying to flash FPGA FW but in Quartus I always get this error. "Flash loader IP not loaded on device 1" see log below. /altera_...
NurAiman_M_Intel
6 years agoHi,
You can try to use following solution:
- https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd01102012_443.html
2. ID:209062 Flash Loader IP not loaded on device <number>
CAUSE: You tried to program one or more serial or parallel configuration devices, using a Programmer Object File (.pof) (../../reference/glossary/def_pof.htm). However, the specified device was not configured with the Flash Loader IP.
ACTION: Make sure the Flash Loader IP is loaded on the device, and make sure the POF can communicate with the device, for example, make sure the communications cable is properly attached and the device has power.
Let me know if you need further information.
Thank you.
Aiman
