14 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
14 years ago --- Quote Start --- you can transfer your data by usb but if you can also the data by using networking. --- Quote End --- Can you please explain more ? I am using all the expansion IO for a Terassic ADA module - I did not think the DE1 had a LAN connection ? cheers, Beau
