14 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
14 years ago --- Quote Start --- @BeauWebber how easy would it be to include a EPCS4 configuration eeprom to the MorphicII fpga module design? would [email protected] test .c upload problem need any amendments to work with the EPCS4 ? :) --- Quote End --- Such a configuration eeprom is not really needed - the MorphicII fpga module is programmed over the same USB as transfers data, and it only takes about 100ms for the upload and program. There is an example binary GUI with binary VHDL code that programs the MorphicII and demonstrates transferring data over the USB at full USB2 rates, at : http://www.lab-tools.com/instrumentation/soft-firm-hard-ware/fpga_interface_to_pc/help.html cheers, Beau
