14 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
14 years ago --- Quote Start --- Yes I used synchronous FIFO mode in the FT223H for the data channel. --- Quote End --- Nice! --- Quote Start --- I attach a cropped SignalTapII recording, being clocked at 120MHz. clk_ftdi is a 60 MHz Clock driven from the FTDI chip ... For short bursts SignalTapII shows the data being clocked in or out at every clock, then there is a variable gap between the bursts. --- Quote End --- Very cool! Thanks for uploading the images. The FT2232H definitely looks like the way to go for implementing a USB interface to the FPGA. I'll have to test my FT2232H mini modules :) While you were doing these tests, did you have any conflicts with the FTDI drivers and the USB-Blaster? I've seen cases where I cannot open a COM port while I have SystemConsole with a JTAG connection open. I suspect an issue with the drivers not playing nicely (since the USB-Blaster also uses FTDI drivers). Cheers, Dave
