DanielHC
2 years agoFALC56 E1/T1/J1 Framer; Intel Bus Interface (HPI) to SPI bridge via FPGA
Hi, I'm looking for an Intel Microprocessor 8-bit bus interface converter/bridge to SPI that I'll implement at the FPGA in order to convert the FALC56 bus to another system SPI communication. Also,...
- 2 years ago
Unfortunately we do not have this available on our PSG websites. We may not be able to support your further on this ticket.
I found this on a forum on the item that could be what you looking for:
https://www.edaboard.com/threads/the-first-8-bit-microprocessor-intel-8008-i8008.216692/
We apologies for the inconvenience, I hope we have provided you enough.
EBERLAZARE_I_Intel
2 years agoHi,
I was checking on the host core, if you're using a soft core, which is the Nios II core for example it should look like this:
If that is not what you're looking for, I think you may need to file a separate forum on your device in the correct topic.
