FALC56 E1/T1/J1 Framer; Intel Bus Interface (HPI) to SPI bridge via FPGA
- 2 years ago
Unfortunately we do not have this available on our PSG websites. We may not be able to support your further on this ticket.
I found this on a forum on the item that could be what you looking for:
https://www.edaboard.com/threads/the-first-8-bit-microprocessor-intel-8008-i8008.216692/
We apologies for the inconvenience, I hope we have provided you enough.
I am unsure on your request here, are you looking for a soft or hard processor for your system?
In our Platform Designer in Quartus, our PD will auto add a bridge to satisfy any mismatch bus address width in your Qsys design, but we need more info on what you're trying to achieve.
We are using FALC56 E1/T1/J1 PEF2256 (full p/n: PEF2256EV22), Intel's component.
On the datasheet, I noticed this component is known to use "Intel Microprocessor 8-bit bus interface".
I'm looking for an "Intel Microprocessor 8-bit bus interface" to SPI converter (bridge) that I'll implement at my FPGA (VHDL).
This bridge should convert "Intel Microprocessor 8-bit bus interface" (parallel) to SPI (serial) and vice versa.
I'm asking here because I didn't find any pseudo code or examples on the internet regarding the "Intel Microprocessor 8-bit bus interface" protocol especially how to convert it to SPI.
Any documents, code examples, or even all the bridge code will help me a lot.
