Facing some placement issue in F-tile of agilix board, while trying to compile Ethernet and JESD204C
Thanks for contacting Intel. I'm assigned to support request.
I'll investigate on this case related to JESD & ETH and get back to you soon once I have any finding.
Meanwhile can I check with you on following details:
- Quartus Device name you are using? (Assignment -> Device)
- Are you able to share the design? (Archived)
Thanks for your patience.
HarshX
- SreekanthB2 years ago
Hey Hii.
Thanks for responding, the board I am using is AGFB027R24C2E2VR2.
Sorry I cant share my design but here is the .qsf of the design.
# Copyright (C) 2022 Intel Corporation. All rights reserved.
# Your use of Intel Corporation's design tools, logic functions
# and other software and tools, and any partner logic
# functions, and any output files from any of the foregoing
# (including device programming or simulation files), and any
# associated documentation or information are expressly subject
# to the terms and conditions of the Intel Program License
# Subscription Agreement, the Intel Quartus Prime License Agreement,
# the Intel FPGA IP License Agreement, or other applicable license
# agreement, including, without limitation, that your use is for
# the sole purpose of programming logic devices manufactured by
# Intel and sold by Intel or its authorized distributors. Please
# refer to the applicable agreement for further details, at
# https://fpgasoftware.intel.com/eula.
# Quartus Prime
# Version 22.3.0 Build 104 09/14/2022 SC Pro Edition
# Date created = 12:08:55 December 16, 2022
# Notes:
# 1) The default values for assignments are stored in the file:
# ghrd_agfb027r24c2e2vr0_assignment_defaults.qdf
# If this file doesn't exist, see file:
# assignment_defaults.qdf
# 2) Intel recommends that you do not modify this file. This
# file is updated automatically by the Quartus Prime software
# and any changes you make may be lost or overwritten.
# Project-Wide Assignments
set_global_assignment -name ORIGINAL_QUARTUS_VERSION 21.3.0
set_global_assignment -name PROJECT_CREATION_TIME_DATE "11:25:44 NOVEMBER 24, 2021"
set_global_assignment -name LAST_QUARTUS_VERSION "22.3.0 Pro Edition"
set_global_assignment -name PROJECT_OUTPUT_DIRECTORY output_files
set_global_assignment -name DESIGN_ASSISTANT_INCLUDE_IP_BLOCKS ON
set_global_assignment -name FLOW_DISABLE_ASSEMBLER OFF# Pin & Location Assignments
set_location_assignment PIN_CY48 -to FBR_CLK_100M
set_location_assignment PIN_BC49 -to FTILE_REFCLK
set_location_assignment PIN_BE49 -to "FTILE_REFCLK(n)"
set_location_assignment PIN_CY32 -to FTILE_OUTCLK
set_location_assignment PIN_DA33 -to "FTILE_OUTCLK(n)"
set_location_assignment PIN_CT42 -to TOD_REFCLK
set_location_assignment PIN_CR43 -to "TOD_REFCLK(n)"
set_location_assignment PIN_BG55 -to FTILE_RX_SERIAL[0]
set_location_assignment PIN_BH54 -to FTILE_RX_SERIAL_N[0]
set_location_assignment PIN_BK52 -to FTILE_TX_SERIAL[0] -comment "PIN_BK52 as per schematic"
set_location_assignment PIN_BJ51 -to FTILE_TX_SERIAL_N[0] -comment "PIN_BJ51 as per schematic"
set_location_assignment PIN_DF46 -to AG_FBR_RSTN
set_location_assignment PIN_Y42 -to MASTER_TOD_PPS
set_location_assignment PIN_U5 -to DDR4_HPS_RCLK
set_location_assignment PIN_T6 -to "DDR4_HPS_RCLK(n)"
set_location_assignment PIN_AH10 -to HPS_OSC_CLK
set_location_assignment PIN_L7 -to DDR4_HPS_MEM_CK[0]
set_location_assignment PIN_M8 -to DDR4_HPS_MEM_CK_N[0]
set_location_assignment PIN_U11 -to DDR4_HPS_MEM_A[0]
set_location_assignment PIN_T12 -to DDR4_HPS_MEM_A[1]
set_location_assignment PIN_W11 -to DDR4_HPS_MEM_A[2]
set_location_assignment PIN_Y12 -to DDR4_HPS_MEM_A[3]
set_location_assignment PIN_U9 -to DDR4_HPS_MEM_A[4]
set_location_assignment PIN_T10 -to DDR4_HPS_MEM_A[5]
set_location_assignment PIN_W9 -to DDR4_HPS_MEM_A[6]
set_location_assignment PIN_Y10 -to DDR4_HPS_MEM_A[7]
set_location_assignment PIN_U7 -to DDR4_HPS_MEM_A[8]
set_location_assignment PIN_T8 -to DDR4_HPS_MEM_A[9]
set_location_assignment PIN_W7 -to DDR4_HPS_MEM_A[10]
set_location_assignment PIN_Y8 -to DDR4_HPS_MEM_A[11]
set_location_assignment PIN_Y6 -to DDR4_HPS_MEM_A[12]
set_location_assignment PIN_U3 -to DDR4_HPS_MEM_A[13]
set_location_assignment PIN_T4 -to DDR4_HPS_MEM_A[14]
set_location_assignment PIN_W3 -to DDR4_HPS_MEM_A[15]
set_location_assignment PIN_Y4 -to DDR4_HPS_MEM_A[16]
set_location_assignment PIN_P12 -to DDR4_HPS_MEM_ACT_N[0]
set_location_assignment PIN_T2 -to DDR4_HPS_MEM_BA[0]
set_location_assignment PIN_W1 -to DDR4_HPS_MEM_BA[1]
set_location_assignment PIN_Y2 -to DDR4_HPS_MEM_BG[0]
set_location_assignment PIN_R9 -to DDR4_HPS_MEM_CKE[0]
set_location_assignment PIN_R11 -to DDR4_HPS_MEM_CS_N[0]
set_location_assignment PIN_R7 -to DDR4_HPS_MEM_CS_N[1]
set_location_assignment PIN_L9 -to DDR4_HPS_MEM_ODT[0]
set_location_assignment PIN_M12 -to DDR4_HPS_MEM_RESET_N[0]
set_location_assignment PIN_P8 -to DDR4_HPS_MEM_PAR[0]
set_location_assignment PIN_W5 -to DDR4_HPS_RZQ
set_location_assignment PIN_U1 -to DDR4_HPS_MEM_ALERT_N[0]
set_location_assignment PIN_L3 -to DDR4_HPS_MEM_DQS[0]
set_location_assignment PIN_G3 -to DDR4_HPS_MEM_DQS[1]
set_location_assignment PIN_U15 -to DDR4_HPS_MEM_DQS[2]
set_location_assignment PIN_L15 -to DDR4_HPS_MEM_DQS[3]
set_location_assignment PIN_A7 -to DDR4_HPS_MEM_DQS[4]
set_location_assignment PIN_G9 -to DDR4_HPS_MEM_DQS[5]
set_location_assignment PIN_L21 -to DDR4_HPS_MEM_DQS[6]
set_location_assignment PIN_U21 -to DDR4_HPS_MEM_DQS[7]
set_location_assignment PIN_AA5 -to DDR4_HPS_MEM_DQS[8]
set_location_assignment PIN_M4 -to DDR4_HPS_MEM_DQS_N[0]
set_location_assignment PIN_F4 -to DDR4_HPS_MEM_DQS_N[1]
set_location_assignment PIN_T16 -to DDR4_HPS_MEM_DQS_N[2]
set_location_assignment PIN_M16 -to DDR4_HPS_MEM_DQS_N[3]
set_location_assignment PIN_B8 -to DDR4_HPS_MEM_DQS_N[4]
set_location_assignment PIN_F10 -to DDR4_HPS_MEM_DQS_N[5]
set_location_assignment PIN_M22 -to DDR4_HPS_MEM_DQS_N[6]
set_location_assignment PIN_T22 -to DDR4_HPS_MEM_DQS_N[7]
set_location_assignment PIN_AB6 -to DDR4_HPS_MEM_DQS_N[8]
set_location_assignment PIN_L1 -to DDR4_HPS_MEM_DQ[0]
set_location_assignment PIN_M6 -to DDR4_HPS_MEM_DQ[1]
set_location_assignment PIN_R1 -to DDR4_HPS_MEM_DQ[2]
set_location_assignment PIN_P2 -to DDR4_HPS_MEM_DQ[3]
set_location_assignment PIN_R5 -to DDR4_HPS_MEM_DQ[4]
set_location_assignment PIN_M2 -to DDR4_HPS_MEM_DQ[5]
set_location_assignment PIN_P6 -to DDR4_HPS_MEM_DQ[6]
set_location_assignment PIN_L5 -to DDR4_HPS_MEM_DQ[7]
set_location_assignment PIN_G5 -to DDR4_HPS_MEM_DQ[8]
set_location_assignment PIN_F6 -to DDR4_HPS_MEM_DQ[9]
set_location_assignment PIN_G1 -to DDR4_HPS_MEM_DQ[10]
set_location_assignment PIN_J5 -to DDR4_HPS_MEM_DQ[11]
set_location_assignment PIN_F2 -to DDR4_HPS_MEM_DQ[12]
set_location_assignment PIN_K2 -to DDR4_HPS_MEM_DQ[13]
set_location_assignment PIN_J1 -to DDR4_HPS_MEM_DQ[14]
set_location_assignment PIN_K6 -to DDR4_HPS_MEM_DQ[15]
set_location_assignment PIN_U13 -to DDR4_HPS_MEM_DQ[16]
set_location_assignment PIN_T18 -to DDR4_HPS_MEM_DQ[17]
set_location_assignment PIN_Y14 -to DDR4_HPS_MEM_DQ[18]
set_location_assignment PIN_U17 -to DDR4_HPS_MEM_DQ[19]
set_location_assignment PIN_W13 -to DDR4_HPS_MEM_DQ[20]
set_location_assignment PIN_Y18 -to DDR4_HPS_MEM_DQ[21]
set_location_assignment PIN_T14 -to DDR4_HPS_MEM_DQ[22]
set_location_assignment PIN_W17 -to DDR4_HPS_MEM_DQ[23]
set_location_assignment PIN_M18 -to DDR4_HPS_MEM_DQ[24]
set_location_assignment PIN_L17 -to DDR4_HPS_MEM_DQ[25]
set_location_assignment PIN_R17 -to DDR4_HPS_MEM_DQ[26]
set_location_assignment PIN_L13 -to DDR4_HPS_MEM_DQ[27]
set_location_assignment PIN_M14 -to DDR4_HPS_MEM_DQ[28]
set_location_assignment PIN_R13 -to DDR4_HPS_MEM_DQ[29]
set_location_assignment PIN_P18 -to DDR4_HPS_MEM_DQ[30]
set_location_assignment PIN_P14 -to DDR4_HPS_MEM_DQ[31]
set_location_assignment PIN_D6 -to DDR4_HPS_MEM_DQ[32]
set_location_assignment PIN_E5 -to DDR4_HPS_MEM_DQ[33]
set_location_assignment PIN_E9 -to DDR4_HPS_MEM_DQ[34]
set_location_assignment PIN_C5 -to DDR4_HPS_MEM_DQ[35]
set_location_assignment PIN_D10 -to DDR4_HPS_MEM_DQ[36]
set_location_assignment PIN_B6 -to DDR4_HPS_MEM_DQ[37]
set_location_assignment PIN_B10 -to DDR4_HPS_MEM_DQ[38]
set_location_assignment PIN_A9 -to DDR4_HPS_MEM_DQ[39]
set_location_assignment PIN_F12 -to DDR4_HPS_MEM_DQ[40]
set_location_assignment PIN_J11 -to DDR4_HPS_MEM_DQ[41]
set_location_assignment PIN_G7 -to DDR4_HPS_MEM_DQ[42]
set_location_assignment PIN_K8 -to DDR4_HPS_MEM_DQ[43]
set_location_assignment PIN_F8 -to DDR4_HPS_MEM_DQ[44]
set_location_assignment PIN_G11 -to DDR4_HPS_MEM_DQ[45]
set_location_assignment PIN_J7 -to DDR4_HPS_MEM_DQ[46]
set_location_assignment PIN_K12 -to DDR4_HPS_MEM_DQ[47]
set_location_assignment PIN_R19 -to DDR4_HPS_MEM_DQ[48]
set_location_assignment PIN_P20 -to DDR4_HPS_MEM_DQ[49]
set_location_assignment PIN_M20 -to DDR4_HPS_MEM_DQ[50]
set_location_assignment PIN_L19 -to DDR4_HPS_MEM_DQ[51]
set_location_assignment PIN_L23 -to DDR4_HPS_MEM_DQ[52]
set_location_assignment PIN_R23 -to DDR4_HPS_MEM_DQ[53]
set_location_assignment PIN_P24 -to DDR4_HPS_MEM_DQ[54]
set_location_assignment PIN_M24 -to DDR4_HPS_MEM_DQ[55]
set_location_assignment PIN_W19 -to DDR4_HPS_MEM_DQ[56]
set_location_assignment PIN_T20 -to DDR4_HPS_MEM_DQ[57]
set_location_assignment PIN_W23 -to DDR4_HPS_MEM_DQ[58]
set_location_assignment PIN_U23 -to DDR4_HPS_MEM_DQ[59]
set_location_assignment PIN_Y24 -to DDR4_HPS_MEM_DQ[60]
set_location_assignment PIN_T24 -to DDR4_HPS_MEM_DQ[61]
set_location_assignment PIN_Y20 -to DDR4_HPS_MEM_DQ[62]
set_location_assignment PIN_U19 -to DDR4_HPS_MEM_DQ[63]
set_location_assignment PIN_AA1 -to DDR4_HPS_MEM_DQ[64]
set_location_assignment PIN_AD2 -to DDR4_HPS_MEM_DQ[65]
set_location_assignment PIN_AD6 -to DDR4_HPS_MEM_DQ[66]
set_location_assignment PIN_AE7 -to DDR4_HPS_MEM_DQ[67]
set_location_assignment PIN_AE1 -to DDR4_HPS_MEM_DQ[68]
set_location_assignment PIN_AB8 -to DDR4_HPS_MEM_DQ[69]
set_location_assignment PIN_AA7 -to DDR4_HPS_MEM_DQ[70]
set_location_assignment PIN_AB2 -to DDR4_HPS_MEM_DQ[71]
set_location_assignment PIN_R3 -to DDR4_HPS_MEM_DBI[0]
set_location_assignment PIN_J3 -to DDR4_HPS_MEM_DBI[1]
set_location_assignment PIN_W15 -to DDR4_HPS_MEM_DBI[2]
set_location_assignment PIN_R15 -to DDR4_HPS_MEM_DBI[3]
set_location_assignment PIN_E7 -to DDR4_HPS_MEM_DBI[4]
set_location_assignment PIN_J9 -to DDR4_HPS_MEM_DBI[5]
set_location_assignment PIN_R21 -to DDR4_HPS_MEM_DBI[6]
set_location_assignment PIN_W21 -to DDR4_HPS_MEM_DBI[7]
set_location_assignment PIN_AA3 -to DDR4_HPS_MEM_DBI[8]
set_location_assignment PIN_AC15 -to HPS_SDMMC_CCLK
set_location_assignment PIN_AL15 -to HPS_SDMMC_CMD
set_location_assignment PIN_AJ11 -to HPS_SDMMC_D0
set_location_assignment PIN_AM16 -to HPS_SDMMC_D1
set_location_assignment PIN_AH12 -to HPS_SDMMC_D2
set_location_assignment PIN_AN15 -to HPS_SDMMC_D3
set_location_assignment PIN_AG13 -to HPS_SDMMC_D4
set_location_assignment PIN_AP16 -to HPS_SDMMC_D5
set_location_assignment PIN_AF14 -to HPS_SDMMC_D6
set_location_assignment PIN_AT16 -to HPS_SDMMC_D7
set_location_assignment PIN_AF10 -to HPS_EMAC1_TX_CLK
set_location_assignment PIN_AU11 -to HPS_EMAC1_TX_CTL
set_location_assignment PIN_AG7 -to HPS_EMAC1_TXD0
set_location_assignment PIN_AP12 -to HPS_EMAC1_TXD1
set_location_assignment PIN_AD12 -to HPS_EMAC1_TXD2
set_location_assignment PIN_AM12 -to HPS_EMAC1_TXD3
set_location_assignment PIN_AF8 -to HPS_EMAC1_RX_CLK
set_location_assignment PIN_AT12 -to HPS_EMAC1_RX_CTL
set_location_assignment PIN_AC13 -to HPS_EMAC1_RXD0
set_location_assignment PIN_AN11 -to HPS_EMAC1_RXD1
set_location_assignment PIN_AD10 -to HPS_EMAC1_RXD2
set_location_assignment PIN_AL11 -to HPS_EMAC1_RXD3
set_location_assignment PIN_AB10 -to HPS_EMAC1_MDIO
set_location_assignment PIN_AJ13 -to HPS_EMAC1_MDC
set_location_assignment PIN_AC11 -to HPS_I2C1_SDA
set_location_assignment PIN_AT10 -to HPS_I2C1_SCL
set_location_assignment PIN_AB14 -to HPS_SPIM0_CLK
set_location_assignment PIN_AH14 -to HPS_SPIM0_MOSI
set_location_assignment PIN_AB12 -to HPS_SPIM0_MISO
set_location_assignment PIN_AJ9 -to HPS_SPIM0_SS0_N
set_location_assignment PIN_AG9 -to HPS_SPIM1_CLK
set_location_assignment PIN_AT14 -to HPS_SPIM1_MOSI
set_location_assignment PIN_AF12 -to HPS_SPIM1_MISO
set_location_assignment PIN_AU13 -to HPS_SPIM1_SS0_N
set_location_assignment PIN_AP14 -to HPS_SPIM1_SS1_N
set_location_assignment PIN_AD8 -to HPS_UART1_TX
set_location_assignment PIN_AP10 -to HPS_UART1_RX
set_location_assignment PIN_AU15 -to HPS_GPIO0_IO11
set_location_assignment PIN_AJ7 -to HPS_GPIO0_IO12
set_location_assignment PIN_AL13 -to HPS_GPIO0_IO13
set_location_assignment PIN_AH8 -to HPS_GPIO0_IO14
set_location_assignment PIN_AM14 -to HPS_GPIO0_IO15
set_location_assignment PIN_AD14 -to HPS_GPIO0_IO16
set_location_assignment PIN_AN13 -to HPS_GPIO0_IO17
set_location_assignment PIN_AG11 -to HPS_GPIO0_IO18
set_location_assignment PIN_AC9 -to HPS_GPIO1_IO16
set_location_assignment PIN_AM10 -to HPS_GPIO1_IO17# Classic Timing Assignments
set_global_assignment -name MIN_CORE_JUNCTION_TEMP 0
set_global_assignment -name MAX_CORE_JUNCTION_TEMP 100
set_global_assignment -name TIMING_ANALYZER_MULTICORNER_ANALYSIS ON# Compiler Assignments
set_global_assignment -name OPTIMIZATION_MODE "SUPERIOR PERFORMANCE WITH MAXIMUM PLACEMENT EFFORT"# Analysis & Synthesis Assignments
set_global_assignment -name TOP_LEVEL_ENTITY ghrd_agilex_top
set_global_assignment -name FAMILY Agilex
set_global_assignment -name IP_SEARCH_PATHS "intel_custom_ip/**/*;custom_ip/**/*"# Fitter Assignments
set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR 1
set_global_assignment -name DEVICE AGFB027R24C2E2VR2
set_global_assignment -name STRATIXV_CONFIGURATION_SCHEME "ACTIVE SERIAL X4"
set_global_assignment -name ACTIVE_SERIAL_CLOCK AS_FREQ_125MHZ
set_global_assignment -name USE_PWRMGT_SCL SDM_IO14
set_global_assignment -name USE_PWRMGT_SDA SDM_IO11
#set_global_assignment -name VID_OPERATION_MODE "PMBUS MASTER"
set_global_assignment -name USE_CONF_DONE SDM_IO16
set_global_assignment -name USE_INIT_DONE SDM_IO0
set_global_assignment -name BLOCK_RAM_TO_MLAB_CELL_CONVERSION OFF
set_global_assignment -name ENABLE_ED_CRC_CHECK ON
set_global_assignment -name MINIMUM_SEU_INTERVAL 10000
set_global_assignment -name DEVICE_INITIALIZATION_CLOCK OSC_CLK_1_125MHZ
set_global_assignment -name QII_AUTO_PACKED_REGISTERS "SPARSE AUTO"# EDA Netlist Writer Assignments
set_global_assignment -name EDA_SIMULATION_TOOL "<None>"# Assembler Assignments
set_global_assignment -name AUTO_RESTART_CONFIGURATION OFF
set_global_assignment -name PWRMGT_PAGE_COMMAND_ENABLE ON
set_global_assignment -name PWRMGT_BUS_SPEED_MODE "100 KHZ"
set_global_assignment -name PWRMGT_SLAVE_DEVICE_TYPE OTHER
set_global_assignment -name PWRMGT_SLAVE_DEVICE0_ADDRESS 6D
set_global_assignment -name PWRMGT_SLAVE_DEVICE1_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE2_ADDRESS 00
set_global_assignment -name PWRMGT_VOLTAGE_OUTPUT_FORMAT "LINEAR FORMAT"
set_global_assignment -name PWRMGT_LINEAR_FORMAT_N "-10"
set_global_assignment -name PWRMGT_PAGE_COMMAND_PAYLOAD 0
set_global_assignment -name HPS_INITIALIZATION "HPS FIRST"# Signal Tap Assignments
set_global_assignment -name ENABLE_SIGNALTAP OFF# Power Estimation Assignments
set_global_assignment -name POWER_APPLY_THERMAL_MARGIN ADDITIONAL# ------------------------------------------
# start ENTITY(f_tile_soft_reset_ctlr_ip_v1)# Project-Wide Assignments
# ========================# end ENTITY(f_tile_soft_reset_ctlr_ip_v1)
# start ENTITY(ftile_ag_v0)# Project-Wide Assignments
# ========================set_location_assignment PIN_DD38 -to jesd_sysref
set_location_assignment PIN_AJ49 -to jesd_gt_ref_clk
set_instance_assignment -name IO_STANDARD 1.2V -to cpld_100mhz -entity ghrd_agilex_top
set_instance_assignment -name IO_STANDARD 1.2V -to cpld_reset_n -entity ghrd_agilex_top
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to jesd_device_clock -entity ghrd_agilex_top
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to jesd_sysref -entity ghrd_agilex_top
set_location_assignment PIN_DD36 -to jesd_device_clock
set_location_assignment PIN_AK52 -to tx_p[0]
set_location_assignment PIN_AG55 -to rx_p[0]
set_location_assignment PIN_AV52 -to tx_p[1]
set_location_assignment PIN_AR55 -to rx_p[1]
set_location_assignment PIN_AP52 -to tx_p[2]
set_location_assignment PIN_AL55 -to rx_p[2]
set_location_assignment PIN_R49 -to tx_p[3]
set_location_assignment PIN_K52 -to rx_p[3]
set_instance_assignment -name HSSI_PARAMETER "rx_ac_couple_enable=ENABLE" -to rx_p[0] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_onchip_termination=RX_ONCHIP_TERMINATION_R_2" -to rx_p[0] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_ac_couple_enable=ENABLE" -to rx_p[1] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_onchip_termination=RX_ONCHIP_TERMINATION_R_2" -to rx_p[1] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_ac_couple_enable=ENABLE" -to rx_p[2] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_onchip_termination=RX_ONCHIP_TERMINATION_R_2" -to rx_p[2] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_ac_couple_enable=ENABLE" -to rx_p[3] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_onchip_termination=RX_ONCHIP_TERMINATION_R_2" -to rx_p[3] -entity ghrd_agilex_topset_instance_assignment -name HSSI_PARAMETER "rx_ac_couple_enable=ENABLE" -to rx_p -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_onchip_termination=RX_ONCHIP_TERMINATION_R_2" -to rx_p -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_main_tap=46" -to tx_p -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_pre_tap_1=0" -to tx_p -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_pre_tap_2=0" -to tx_p -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_post_tap_1=8" -to tx_p -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_ac_couple_enable=ENABLE" -to eth_rx_p -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_onchip_termination=RX_ONCHIP_TERMINATION_R_2" -to eth_rx_p -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_pre_tap_2=0" -to eth_tx_p -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_post_tap_1=5" -to eth_tx_p -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_pre_tap_1=0" -to eth_tx_p -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_main_tap=35" -to eth_tx_p -entity ghrd_agilex_topset_instance_assignment -name IP_TILE_ASSIGNMENT Z1577B_X5_Y166_N0 -to ghrd_agilex_top|JESD204C_top_dut|wn_JESD204C_dut|ftile_clocking|systemclk_f_0 -entity ghrd_agilex_top
set_instance_assignment -name IP_BB_LOCATION FGT_REFCLK_5 -to ghrd_agilex_top|JESD204C_top_dut|wn_JESD204C_dut|ftile_clocking|systemclk_f_0|x_hip|gen_refclk_fgt_bb_[5].enabled.inst -entity ghrd_agilex_top
set_instance_assignment -name IP_BB_LOCATION SYSTEM_PLL_0 -to ghrd_agilex_top|JESD204C_top_dut|wn_JESD204C_dut|ftile_clocking|systemclk_f_0|x_hip|gen_systempll_bb_[0].enabled.inst -entity ghrd_agilex_top
set_instance_assignment -name IP_TILE_ASSIGNMENT Z1577B_X5_Y166_N0 -to ghrd_agilex_top|JESD204C_top_dut|wn_JESD204C_dut|jesd_inst|intel_jesd204c_f_0 -entity ghrd_agilex_top
set_instance_assignment -name IP_BB_LOCATION EHIP400G_ST_X1_5_RX -to ghrd_agilex_top|JESD204C_top_dut|wn_JESD204C_dut|jesd_inst|intel_jesd204c_f_0|j204c_f_hip_jesd204c_200mhz_bw_intel_jesd204c_f_201_anrsqiy_inst|hip_bb|a[0].bb_f_ehip_rx_inst0 -entity ghrd_agilex_top
set_instance_assignment -name IP_BB_LOCATION EHIP400G_ST_X1_5_TX -to ghrd_agilex_top|JESD204C_top_dut|wn_JESD204C_dut|jesd_inst|intel_jesd204c_f_0|j204c_f_hip_jesd204c_200mhz_bw_intel_jesd204c_f_201_anrsqiy_inst|hip_bb|a[0].bb_f_ehip_tx_inst0 -entity ghrd_agilex_top
set_instance_assignment -name IP_BB_LOCATION FGT_Q2_CH2_RX -to ghrd_agilex_top|JESD204C_top_dut|wn_JESD204C_dut|jesd_inst|intel_jesd204c_f_0|j204c_f_hip_jesd204c_200mhz_bw_intel_jesd204c_f_201_anrsqiy_inst|hip_bb|bb_f_ux_rx_inst0 -entity ghrd_agilex_top
set_instance_assignment -name IP_BB_LOCATION FGT_Q2_CH2_TX -to ghrd_agilex_top|JESD204C_top_dut|wn_JESD204C_dut|jesd_inst|intel_jesd204c_f_0|j204c_f_hip_jesd204c_200mhz_bw_intel_jesd204c_f_201_anrsqiy_inst|hip_bb|bb_f_ux_tx_inst0 -entity ghrd_agilex_top
# end ENTITY(ftile_ag_v0)
# start ENTITY(ghrd_agilex_top)# Fitter Assignments
# ==================# Design Partition Assignments
# ============================# Logic Generation and Fitter Assignments
# =======================================# end ENTITY(ghrd_agilex_top)
# ---------------------------# Ordering Sensitive Assignments
set_global_assignment -name USE_SIGNALTAP_FILE prach_debug.stp
#set_global_assignment -name IP_FILE ../../designs/lib/qsys_comp/ip/ram_32i_32o_122kd_dc.ip
set_location_assignment PIN_DF34 -to DSP_CLK_491M
set_location_assignment PIN_T40 -to MASTER_TOD_PPS_IN
set_global_assignment -name SEED 1
set_global_assignment -name TIMING_ANALYZER_REPORT_SCRIPT timing_report.tcl
set_global_assignment -name TIMING_ANALYZER_REPORT_NUM_WORST_CASE_TIMING_PATHS 200
set_instance_assignment -name MAX_FANOUT 100 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l1_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2* -entity ghrd_agilex_top -disable
set_instance_assignment -name MAX_FANOUT 100 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2* -entity ghrd_agilex_top -disable
set_instance_assignment -name MAX_FANOUT 100 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2_delay* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_im|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_im|u0_m0_wo0_cma0* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_im|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_im|u0_m0_wo0_cma1* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_im|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_im|u0_m0_wo0_wi0_r0_delayr*_mem_dmem* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_im|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_im|u0_m0_wo0_wi0_r0_delayr*_q* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_im|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_im|u0_m0_wo0_wi0_r0_delayr*_delay_* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l1_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_im|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_im|u0_m0_wo0_cma0* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l1_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_im|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_im|u0_m0_wo0_cma1* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l1_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_im|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_im|u0_m0_wo0_wi0_r0_delayr*_mem_dmem* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l1_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_im|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_im|u0_m0_wo0_wi0_r0_delayr*_q* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l1_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_im|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_im|u0_m0_wo0_wi0_r0_delayr*_delay_* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l1_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_re|u0_m0_wo0_cma0* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l1_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_re|u0_m0_wo0_cma1* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l1_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_re|u0_m0_wo0_wi0_r0_delayr*_mem_dmem* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l1_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_re|u0_m0_wo0_wi0_r0_delayr*_q* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l1_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_re|u0_m0_wo0_wi0_r0_delayr*_delay_* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_re|u0_m0_wo0_cma0* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_re|u0_m0_wo0_cma1* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_re|u0_m0_wo0_wi0_r0_delayr*_mem_dmem* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_re|u0_m0_wo0_wi0_r0_delayr*_q* -entity ghrd_agilex_top -disable
set_instance_assignment -name DUPLICATE_ATOM 100 -from soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theDDC_l2_vunroll_cunroll_x|theHB7_vunroll_cunroll_x|thescale_HB7_re|redist3_xIn_v_2_delay_0[0] -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|thechan_filter_re|u0_m0_wo0_wi0_r0_delayr*_delay_* -entity ghrd_agilex_top -disable
set_instance_assignment -name MAX_FANOUT 100 -to *theDUT_vunroll_cunroll_x|therouting_reg_hb72chan_l2_cunroll_x|redist0_ChannelIn_cunroll_x_in_2_dv_tpl_3_q* -entity ghrd_agilex_top -disable
set_instance_assignment -name MAX_FANOUT 100 -to *theDUT_vunroll_cunroll_x|therouting_reg_hb72chan_l1_cunroll_x|redist0_ChannelIn_cunroll_x_in_2_dv_tpl_3_q* -entity ghrd_agilex_top -disable
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|u_ifft_reg_map|ifft_shift_l1_1d[*] -entity ghrd_agilex_top -disable
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|u_ifft_reg_map|ifft_shift_l1_1d[*] -entity ghrd_agilex_top -disable
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_prach_top|u_prach_ant_mux|avst_sink_valid_1d_dup1* -entity ghrd_agilex_top -disable
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_prach_top|u_prach_ant_mux|avst_sink_valid_1d_dup1* -entity ghrd_agilex_top -disable
set_global_assignment -name VERILOG_FILE ../../designs/lib/qsys_comp/jesd204c_srcs/wn_JESD204C_200mhz_bw.v
set_global_assignment -name VERILOG_FILE ../../designs/lib/qsys_comp/jesd204c_srcs/wn_JESD204C_100mhz_bw.v
set_global_assignment -name SYSTEMVERILOG_FILE ../../designs/lib/qsys_comp/jesd204c_srcs/JESD204C_top.sv
set_global_assignment -name VERILOG_FILE ghrd_agilex_top.v
set_global_assignment -name SYSTEMVERILOG_FILE custom_ip/timing_adapter/timing_adapter.sv
set_global_assignment -name SYSTEMVERILOG_FILE custom_ip/timing_adapter/timing_adapter_fifo.sv
set_global_assignment -name IP_FILE ip/qsys_top/qsys_top_sc_fifo_0.ip
set_global_assignment -name IP_FILE gpio_ftile_outclk.ip
set_global_assignment -name VHDL_FILE measure_refclk.vhd
set_global_assignment -name VERILOG_FILE custom_ip/debounce/debounce.v
set_global_assignment -name VERILOG_FILE custom_ip/edge_detect/altera_edge_detector.v
set_global_assignment -name SDC_FILE ghrd_timing.sdc
set_global_assignment -name SDC_FILE ftile_25gbe.sdc
set_global_assignment -name QSYS_FILE qsys_top.qsys
set_global_assignment -name QSYS_FILE ftile_subsys.qsys
set_global_assignment -name QSYS_FILE master_tod_subsys.qsys
set_global_assignment -name QSYS_FILE rx_tod_subsys.qsys
set_global_assignment -name QSYS_FILE tx_tod_subsys.qsys
set_global_assignment -name QSYS_FILE dma_subsys.qsys
set_global_assignment -name QSYS_FILE subsys_ftile_25gbe_rx_dma.qsys
set_global_assignment -name QSYS_FILE subsys_ftile_25gbe_tx_dma.qsys
set_global_assignment -name QSYS_FILE hps_subsys.qsys
set_global_assignment -name IP_FILE ip/qsys_top/clk_100.ip
set_global_assignment -name IP_FILE ip/qsys_top/rst_in.ip
set_global_assignment -name IP_FILE ip/qsys_top/ninitdone_rst.ip
set_global_assignment -name IP_FILE ip/qsys_top/sysid.ip
set_global_assignment -name IP_FILE ip/qsys_top/tod_clk_156.ip
set_global_assignment -name IP_FILE ip/qsys_top/rst_clk_156_tod.ip
set_global_assignment -name IP_FILE ip/qsys_top/rst_clk_201.ip
set_global_assignment -name IP_FILE ip/qsys_top/rst_clk_390_ftile_rec_div.ip
set_global_assignment -name IP_FILE ip/qsys_top/rst_clk_390_ftile_tx_div.ip
set_global_assignment -name IP_FILE ip/qsys_top/ftile_390_clkout_1588.ip
set_global_assignment -name IP_FILE ip/qsys_top/ftile_ref_sys_clk.ip
set_global_assignment -name IP_FILE ip/qsys_top/ftile_debug_status_pio.ip
set_global_assignment -name IP_FILE ip/qsys_top/avmm_csr.ip
set_global_assignment -name IP_FILE ip/qsys_top/user_rst_clkgate_0.ip
set_global_assignment -name IP_FILE ip/qsys_top/axi_bridge_for_acp_0.ip
set_global_assignment -name IP_FILE ip/qsys_top/dma_clk_out.ip
set_global_assignment -name IP_FILE ip/ftile_subsys/ftile_clk.ip
set_global_assignment -name IP_FILE ip/ftile_subsys/ftile_hip.ip
set_global_assignment -name IP_FILE ip/ftile_subsys/ftile_ptp_sampling_pll.ip
set_global_assignment -name IP_FILE ip/ftile_subsys/ftile_clk_tx_div.ip
set_global_assignment -name IP_FILE ip/ftile_subsys/ftile_clk_rec_div.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/scan_tod_clk.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/master_tod_rst.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/pll_tod_rst.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/csr_tod_clk.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/master_tod.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/tod_pll_interface_adapter_0.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/sync_sampling_pll.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/period_clock_source.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/master_sampling_iopll.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/master_phase_iopll.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/master_tod_load_off_96b.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/master_tod_load_off_64b.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/tod_sync_interface_adapter_0.ip
set_global_assignment -name IP_FILE ip/rx_tod_subsys/rx_tod_synchronizer.ip
set_global_assignment -name IP_FILE ip/rx_tod_subsys/rx_tod_slave.ip
set_global_assignment -name IP_FILE ip/rx_tod_subsys/rx_tod_slave_load_off_64b.ip
set_global_assignment -name IP_FILE ip/tx_tod_subsys/tx_tod_synchronizer.ip
set_global_assignment -name IP_FILE ip/tx_tod_subsys/tx_tod_slave.ip
set_global_assignment -name IP_FILE ip/tx_tod_subsys/tx_tod_slave_load_off_64b.ip
set_global_assignment -name IP_FILE ip/dma_subsys/iopll_clk_avst_div2.ip
set_global_assignment -name IP_FILE ip/dma_subsys/ftile_st_adapter.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_1588_dmaclkout_reset.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_1588_dmaclkout.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_clock.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_ftile_clock.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_tx_dc_fifo.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_reset.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_timestamp_insert.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_fingerprint_fifo.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_fingerprint_compare.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_prefetcher.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_tx_fifo.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_csr.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_timestamp_req.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_ts_fifo.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_read_master.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_dispatcher.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_tx_dma/tx_dma_timestamp_adapter.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_prefetcher.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_csr.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_ftile_clock.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_dispatcher.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_write_master.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_timestamp_adapter.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_pkt_fifo.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_ts_insert.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_pause_ctrl.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_ts_fifo.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_clock.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_pkt_dc_fifo.ip
set_global_assignment -name IP_FILE ip/dma_subsys/subsys_ftile_25gbe_rx_dma/rx_dma_reset.ip
set_global_assignment -name IP_FILE ip/hps_subsys/h2f_lw_clkin.ip
set_global_assignment -name IP_FILE ip/hps_subsys/h2f_lw_rstin.ip
set_global_assignment -name IP_FILE ip/hps_subsys/emif_fm_hps.ip
set_global_assignment -name IP_FILE ip/hps_subsys/h2f_lw_bridge.ip
set_global_assignment -name IP_FILE ip/hps_subsys/f2h_clkin.ip
set_global_assignment -name IP_FILE ip/hps_subsys/f2h_rstin.ip
set_global_assignment -name IP_FILE ip/hps_subsys/f2h_bridge.ip
set_global_assignment -name IP_FILE ip/hps_subsys/h2f_clkin.ip
set_global_assignment -name IP_FILE ip/hps_subsys/h2f_rstin.ip
set_global_assignment -name IP_FILE ip/hps_subsys/h2f_bridge.ip
set_global_assignment -name IP_FILE ip/hps_subsys/fbr_ddr4A_clk.ip
set_global_assignment -name IP_FILE ip/hps_subsys/fbr_ddr4B_clk.ip
set_global_assignment -name IP_FILE ip/hps_subsys/fbr_ddr4A_rst.ip
set_global_assignment -name IP_FILE ip/hps_subsys/h2f_fbr_ddr4A.ip
set_global_assignment -name IP_FILE ip/hps_subsys/fbr_ddr4B_rst.ip
set_global_assignment -name IP_FILE ip/hps_subsys/h2f_fbr_ddr4B.ip
set_global_assignment -name IP_FILE ip/hps_subsys/hps.ip
set_global_assignment -name IP_FILE ip/hps_subsys/emif_cal.ip
set_global_assignment -name IP_FILE ip/qsys_top/rst_clk_402.ip
set_global_assignment -name IP_FILE ip/qsys_top/ocm.ip
set_global_assignment -name IP_FILE ip/qsys_top/f2h_axi_rst.ip
set_global_assignment -name IP_FILE ip/qsys_top/h2f_axi_rst.ip
set_global_assignment -name IP_FILE ip/qsys_top/h2f_lw_axi_rst.ip
set_global_assignment -name IP_FILE ip/qsys_top/fpga_m2ocm_pb.ip
set_global_assignment -name IP_FILE ip/qsys_top/ext_hps_m_master.ip
set_global_assignment -name IP_FILE ip/qsys_top/ftile_hip_i_tx_rst_n_reset.ip
set_global_assignment -name QSYS_FILE subsys_periph.qsys
set_global_assignment -name IP_FILE ip/subsys_periph/periph_clk.ip
set_global_assignment -name IP_FILE ip/subsys_periph/periph_rst_in.ip
set_global_assignment -name IP_FILE ip/subsys_periph/button_pio.ip
set_global_assignment -name IP_FILE ip/subsys_periph/dipsw_pio.ip
set_global_assignment -name IP_FILE ip/subsys_periph/led_pio.ip
set_global_assignment -name IP_FILE ip/subsys_periph/ILC.ip
set_global_assignment -name IP_FILE ip/subsys_periph/pb_cpu_0.ip
set_global_assignment -name QSYS_FILE subsys_jtg_mst.qsys
set_global_assignment -name IP_FILE ip/subsys_jtg_mst/jtag_clk.ip
set_global_assignment -name IP_FILE ip/subsys_jtg_mst/jtag_rst_in.ip
set_global_assignment -name IP_FILE ip/subsys_jtg_mst/hps_m.ip
set_global_assignment -name IP_FILE ip/subsys_jtg_mst/fpga_m.ip
set_global_assignment -name IP_FILE ip/ftile_subsys/rst_ptp_adapter_clk_402.ip
set_global_assignment -name IP_FILE ip/ftile_subsys/ptp_adpt_rst_clk_402.ip
set_global_assignment -name IP_FILE ip/ftile_subsys/ptp_tile_adpt.ip
set_global_assignment -name IP_FILE ip/qsys_top/ptp_adpt_o_clk_pll_402.ip
set_global_assignment -name IP_FILE ip/tx_tod_subsys/tx_stod_valid_gen.ip
set_global_assignment -name IP_FILE ip/rx_tod_subsys/rx_stod_valid_gen.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/mtod_load_off.ip
set_global_assignment -name IP_FILE ip/master_tod_subsys/mtod_valid_gen.ip
set_global_assignment -name IP_FILE iopll_390p625.ip
set_global_assignment -name IP_FILE iopll_491p52.ip
set_global_assignment -name IP_FILE ip/qsys_top/clk_390.ip
set_global_assignment -name IP_FILE ip/qsys_top/clk_491.ip
set_global_assignment -name IP_FILE ip/qsys_top/rst_clk_390.ip
set_global_assignment -name IP_FILE ip/qsys_top/rst_clk_491.ip
set_global_assignment -name IP_FILE ip/qsys_top/rst_ftile_clk_402.ip
set_global_assignment -name IP_FILE ../../generated/eth/fdv_buffer/ip/ram_48i_48o_36d_dc.ip
set_global_assignment -name IP_FILE ../../generated/eth/fdv_buffer/ip/ram_128i_32o_3276d_dc.ip
set_global_assignment -name IP_FILE ../../generated/ORAN/oran_hwtcl_top_ex_design/synthesis/ip_components/oran_hwtcl_top.ip
set_global_assignment -name IP_FILE ../../generated/eCPRI/ecpri_hwtcl_top_ex_design/synthesis/ip_components/ecpri_hwtcl_top.ip
set_global_assignment -name IP_FILE ../../generated/fft_ifft/ip/ff_8i_8o_64d_dc.ip
set_global_assignment -name IP_FILE ../../generated/fft_ifft/ip/ff_64i_64o_4096kd.ip
set_global_assignment -name IP_FILE ../../generated/fft_ifft/ip/ff_32i_32o_1024d_sc.ip
set_global_assignment -name IP_FILE ../../generated/fft_ifft/ip/ff_32i_32o_1024d_dc.ip
set_global_assignment -name IP_FILE ../../generated/fft_ifft/ip/ff_32i_128o_8d_dc.ip
set_global_assignment -name IP_FILE ../../generated/fft_ifft/ip/ff_32i_128o_1024d_dc.ip
set_global_assignment -name IP_FILE ../../generated/fft_ifft/ip/ff_128i_128o_4096d_sc.ip
set_global_assignment -name IP_FILE ../../generated/fft_ifft/ip/ff_128i_128o_2048d_sc.ip
set_global_assignment -name IP_FILE ../../generated/fft_ifft/ip/ff_128i_128o_1024d_sc.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys_comp/ip/ff_32i_32o_32kd_sc.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys_comp/ip/ff_32i_64o_16d_dc.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys_comp/ip/ff_96i_96o_4096kd.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_mm_pb_h2f_bridge.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_wrapper_top.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_rst_csr.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_mm_h2flw_bridge.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_rst_dsp.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_clk_csr.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_clk_dsp.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_clk_eth25g_tx.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_clk_ecpri_tx.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_clk_eth25g_rx.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_clk_ecpri_rx.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_mm_h2f_bridge.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_mm_pb_h2f_lw_bridge.ip
set_global_assignment -name IP_FILE ../../designs/lib/qsys/ip/wrapper/wrapper_clk_prach.ip
set_global_assignment -name IP_FILE ip/qsys_top/qsys_top_tod_timestamp_96b_0.ip
set_global_assignment -name QSYS_FILE ../../designs/lib/qsys/wrapper.qsys
set_global_assignment -name SDC_FILE wrapper.sdc
set_global_assignment -name SDC_FILE ../../generated/ORAN/oran_hwtcl_top_ex_design/synthesis/quartus/oran_ed_agilex.sdc
set_global_assignment -name SDC_FILE ../../generated/eCPRI/ecpri_hwtcl_top_ex_design/synthesis/quartus/ecpri_ed_agilex.sdc
set_global_assignment -name SDC_FILE ../../designs/dspba/DDC/rtl/ddc_2c4ant/ddc_2c4ant_DUT.sdc
set_global_assignment -name IP_FILE ip/qsys_top/cdc_pipeline_0.ip
set_global_assignment -name TCL_SCRIPT_FILE timing_report.tcl
set_global_assignment -name IP_FILE ip/master_tod_subsys/eth_1588_pps.ip
set_global_assignment -name IP_FILE jesd204c_100mhz_bw.ip
set_global_assignment -name IP_FILE device_clock_pll_100mhz.ip
set_global_assignment -name IP_FILE jesd204c_ftile_clocking_100mhz.ip
set_global_assignment -name FLOW_ENABLE_HYPER_RETIMER_FAST_FORWARD ON
set_instance_assignment -name IO_STANDARD 1.2V -to FBR_CLK_100M -entity ghrd_agilex_top
set_instance_assignment -name IO_STANDARD 1.2V -to MASTER_TOD_PPS -entity ghrd_agilex_top
set_instance_assignment -name IO_STANDARD "CURRENT MODE LOGIC (CML)" -to FTILE_REFCLK -entity ghrd_agilex_top
set_instance_assignment -name IO_STANDARD "HIGH SPEED DIFFERENTIAL I/O" -to FTILE_TX_SERIAL[0] -entity ghrd_agilex_top
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to TOD_REFCLK -entity ghrd_agilex_top
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to FTILE_OUTCLK -entity ghrd_agilex_top
set_instance_assignment -name IO_STANDARD "HIGH SPEED DIFFERENTIAL I/O" -to FTILE_RX_SERIAL[0] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_ac_couple_enable=ENABLE" -to FTILE_RX_SERIAL[0] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "rx_onchip_termination=RX_ONCHIP_TERMINATION_R_2" -to FTILE_RX_SERIAL[0] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_main_tap=35" -to FTILE_TX_SERIAL[0] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_pre_tap_1=5" -to FTILE_TX_SERIAL[0] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_pre_tap_2=0" -to FTILE_TX_SERIAL[0] -entity ghrd_agilex_top
set_instance_assignment -name HSSI_PARAMETER "txeq_post_tap_1=0" -to FTILE_TX_SERIAL[0] -entity ghrd_agilex_top
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to DSP_CLK_491M -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|tod_0|tod_timestamp_96b_ts_buf|tod_timestamp_96b_ts_buf|*seconds* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|tod_0|tod_timestamp_96b_ts_buf|tod_timestamp_96b_ts_buf|*seconds* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|tod_0|tod_timestamp_96b_ts_buf|tod_timestamp_96b_ts_buf|rfp_sync_pul* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_xran_timestamp|frame_status_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|u_fft_if|xran_demapper_cplane_dout_ul_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|u_fft_if|xran_demapper_cplane_vout_ul_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|u_fft_if|xran_demapper_cplane_vout_ul_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_frame_sync|auxN_tx_rfp_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|ifft_gain_l1_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|ifft_gain_l1_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|u_fft_if|fft_gain_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|u_fft_if|fft_gain_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|muxsel_l1_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|muxsel_l1_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|u_fft_if|fft_shift_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|ifft_mux_const_l1_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|u_fft_if|hcs_bypass_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|u_fft_if|hcs_bypass_1d* -entity ghrd_agilex_top
set_instance_assignment -name IO_STANDARD "1.2 V" -to MASTER_TOD_PPS_IN -entity ghrd_agilex_top
set_instance_assignment -name MAX_FANOUT 1000 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|rst_dsp_n_2d_dup1* -entity ghrd_agilex_top
set_instance_assignment -name MAX_FANOUT 400 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|ifft_source_valid* -entity ghrd_agilex_top
set_instance_assignment -name DUPLICATE_REGISTER 20 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|u_ifft_blocktostream_DL_OFDM|reset_fanout_mitigation_signal_out[*] -entity ghrd_agilex_top
set_instance_assignment -name DUPLICATE_REGISTER 20 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|u_fft_if|u_streamtoblock_fft_DUT|reset_fanout_mitigation_signal_out[*] -entity ghrd_agilex_top
set_instance_assignment -name MAX_FANOUT 75 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|duc_inst|theChanFilt_DUC_vunroll_cunroll_x|thePoly_phase_Interp_vunroll_cunroll_x|thescale_HB8_re|redist24_xIn_v_2_delay* -entity ghrd_agilex_top
set_instance_assignment -name MAX_FANOUT 75 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|duc_inst|theChanFilt_DUC_vunroll_cunroll_x|thePoly_phase_Interp_vunroll_cunroll_x|thescale_HB8_re|redist24_xIn_v_2* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|tod_0|tod_timestamp_96b_ts_buf|tod_timestamp_96b_ts_buf|rfp_sync_pul* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_xran_timestamp|frame_status_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|u_fft_if|xran_demapper_cplane_dout_ul_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_frame_sync|auxN_tx_rfp_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|u_fft_if|fft_shift_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|ifft_mux_const_l1_1d* -entity ghrd_agilex_top
set_instance_assignment -name DUPLICATE_REGISTER 20 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|duc_inst|reset_fanout_mitigation_signal_out[*] -entity ghrd_agilex_top
set_instance_assignment -name DUPLICATE_REGISTER 50 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|reset_fanout_mitigation_signal_out* -entity ghrd_agilex_top
set_instance_assignment -name MAX_FANOUT 400 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|ifft_source_data* -entity ghrd_agilex_top
set_instance_assignment -name MAX_FANOUT 100 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|therouting_reg_chan_re|redist0_ChannelIn_in_2_dv_tpl_3_q* -entity ghrd_agilex_top
set_instance_assignment -name MAX_FANOUT 100 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_Filter_l1_cunroll_x|theChan_Filter_cunroll_x|therouting_reg_chan_im|redist0_ChannelIn_in_2_dv_tpl_3_q* -entity ghrd_agilex_top
set_instance_assignment -name MAX_FANOUT 100 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|therouting_reg_chan_re|redist0_ChannelIn_in_2_dv_tpl_3_q* -entity ghrd_agilex_top
set_instance_assignment -name MAX_FANOUT 100 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_ul_top|ddc_inst|theDUT_vunroll_cunroll_x|theChan_FIlter_l2_cunroll_x|theChan_Filter_cunroll_x|therouting_reg_chan_im|redist0_ChannelIn_in_2_dv_tpl_3_q* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_dl_fdv_buffer|ram_rden_dup_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_dl_fdv_buffer|ram_rden_dup_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_dl_fdv_buffer|ram_rdaddress_dup_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_dl_fdv_buffer|ram_rdaddress_dup_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_radio_config|blank_prb_flag_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_radio_config|blank_prb_flag_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_prach_top|u_prach_ant_mux|timing_reference_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_prach_top|u_prach_ant_mux|timing_reference_1d* -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|ifft_shift_l1_1d[*] -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|ifft_shift_l1_1d[*] -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|Digital_pow_scale_l1_1d[*] -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to *|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_dl_top|u_ifft_if|Digital_pow_scale_l1_1d[*] -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZATION_REGISTER_CHAIN_LENGTH 3 -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_prach_top|prach_pat_en_1d -entity ghrd_agilex_top
set_instance_assignment -name SYNCHRONIZER_IDENTIFICATION FORCED_IF_ASYNCHRONOUS -to soc_inst|wrapper_0|wrapper_wrapper_top|wrapper_wrapper_top|u_prach_top|prach_pat_en_1d -entity ghrd_agilex_top
set_instance_assignment -name PARTITION_COLOUR 4284809125 -to JESD204C_top -entity ghrd_agilex_top
set_instance_assignment -name PARTITION_COLOUR 4292607854 -to auto_fab_0 -entity ghrd_agilex_top
set_location_assignment PIN_DC39 -to "jesd_sysref(n)"
set_instance_assignment -name PARTITION_COLOUR 4294929372 -to ghrd_agilex_top -entity ghrd_agilex_top
