9 years agoExternal Clock for DE2 board
Hello everyone, I have a simple question. Can we use a function generator as the source for the external clock of the de2 board??? I really want to use a clock frequency other than the ones provided ...
9 years agoWell, this is my VHDL code :
---------------------- Frequency division by 2 ------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; ----------------------------------------- ENTITY freq_div2 IS PORT ( clk : IN STD_LOGIC; reset_n : IN STD_LOGIC; out2 : OUT STD_LOGIC); END freq_div2; ----------------------------------------- ARCHITECTURE example OF freq_div2 IS signal clk_div : std_logic :='0'; BEGIN process (clk, reset_n, clk_div) variable countr : integer range 0 to 7:= 0; begin if reset_n ='0' then countr :=0; elsif (clk'event AND clk = '0') then countr := countr +1; if countr =1 then clk_div <= not clk_div; countr :=0 ; end if; end if; end process; out2 <= clk_div; end example; Then I use the (Pin Planner) to assign the (clk) to the appropriate clock pin. For example (PIN_N2) for (50 MHz). How do you suggest I use the (PLL)?? Thanks a lot.
