15 years agoExtension cable for PCIe
Hi, I have a Arria II GX dev kit and want to use the PCIe interface. I am planning to connect it using an extension cable instead of connecting it directly on the mother board. Any suggestions...
15 years agoAnd somewhat less robust than the nice OneStopSystems solution, the low budget equivalent would be:
2. http://www.hwtools.net/adapter/pe3.html PE3 adapter from hwtools.net 3. the aforementioned PE-FLEX cable from Adec. And newegg has resonably priced PCIe cards with expresscard slots, so if you are using a desktop system, you can have a PCIe connection without leaving the cover off the system.
