Example design: Agilex I-series devkit not detected by lspci (stuck in S_CFG_LINKWD_START)
- 4 years ago
I found the issue.
The default position for the SW3 is defined in the UG as OFF/ON/ON/OFF, to use the refclk from the connector.
The board was received with OFF/OFF/OFF/OFF, to use the on-board refclk.
I set the SW3 as documented and it's now enumerated by the bios and seen in lspci.
Why it doesn't work using the on-board refclks?
Devkit: DK-DEV-AGI027RES
Serial number: AGIPCIE8000248
I receive a new update on R-tile bug issue, it might be one of the root causes of your problem.
Please refer the link below, download and install the patch, the problem shall fixed in future release
https://www.intel.com/content/www/us/en/support/programmable/articles/000090874.html
Let me know if this help, Looking forward to hear back from you
Wincent_C_Intel
Hi @Wincent_Altera,
- I added the smartVID to your project and it programs successfully now.
- I tried 3 different motherboards (up to Gen3x16) and no one detects the card with the 22.1 project and your project.
- I checked several times the physical connection, no issues, it's fully in and it works with all the other PCIe cards we have. Nevertheless, I could only test in lab servers where the card is vertically plugged in due to the PCIe bracket being 1cm taller than the standard size.
Thank you for the patch, I installed it and the project is compiling.
