alexislms
Contributor
4 years agoExample design: Agilex I-series devkit not detected by lspci (stuck in S_CFG_LINKWD_START)
I've been trying to compile a PCI Express example design for the Agilex I-series devkit.
1. Nothing works on the projects provided here ES (21.2 or higher)
Found here: https://www.intel.com/cont...
- 4 years ago
I found the issue.
The default position for the SW3 is defined in the UG as OFF/ON/ON/OFF, to use the refclk from the connector.
The board was received with OFF/OFF/OFF/OFF, to use the on-board refclk.
I set the SW3 as documented and it's now enumerated by the bios and seen in lspci.
Why it doesn't work using the on-board refclks?
Devkit: DK-DEV-AGI027RES
Serial number: AGIPCIE8000248
Wincent_Altera
4 years agoHi,
Can you try the file at the attachment.
also, I suggest trying another Motherboard which is Gen4x16 capable.
Let me know if the problem fixes.
Wincent_C_Intel
alexislms
Contributor
4 years agoHi @Wincent_Altera,
Thank you, it's currently compiling with Quartus Pro 21.2.
At this moment, I don't have a Gen4x16 capable motherboard available, only Gen3x16.
