Example design: Agilex I-series devkit not detected by lspci (stuck in S_CFG_LINKWD_START)
- 4 years ago
I found the issue.
The default position for the SW3 is defined in the UG as OFF/ON/ON/OFF, to use the refclk from the connector.
The board was received with OFF/OFF/OFF/OFF, to use the on-board refclk.
I set the SW3 as documented and it's now enumerated by the bios and seen in lspci.
Why it doesn't work using the on-board refclks?
Devkit: DK-DEV-AGI027RES
Serial number: AGIPCIE8000248
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Allow me some time to look into your issue. I shall come back to you with the findings.
Thank you for your patience.
Wincent_C_Intel
- alexislms4 years ago
Contributor
Hi @Wincent_Altera,
Thank you for your help, we are completely blocked due to this issue and have no way to debug it by ourselves.
Please let me know if you need anything more.
