mac23
3 years agoEthernet without using the Nios II
Is there an ethernet example that does not go through the Nios II processor and send and receives packets from a host computer? My assumption is that if Nios II is used then this means a C program ha...
- 3 years ago
Hi mac23,
You can use TSE MAC ethernet IP without using the NIOS II soft core. AN647 TSE IP example design also did not use Nios II.
AN647 Application note and its example designs are available at below:
zying
ZiYing_Intel
3 years agoHi,
Since no hear any feedback from you, I am now close the case. If you have any question after the case closed, please do feel free to submit another issue.
zying
