mac23
3 years agoEthernet without using the Nios II
Is there an ethernet example that does not go through the Nios II processor and send and receives packets from a host computer? My assumption is that if Nios II is used then this means a C program ha...
- 3 years ago
Hi mac23,
You can use TSE MAC ethernet IP without using the NIOS II soft core. AN647 TSE IP example design also did not use Nios II.
AN647 Application note and its example designs are available at below:
zying
FvM
3 years agoHi,
as far as I'm aware of, there's no support from Intel for hardware TCPIP stack. Neither rocketboard is a suitable source because it's dedicated to FPGA with harware processor system (HPS).
You can find a few hint in this recent same topic thread Re: Hardware TCP/IP stack - Intel Community
