mac23
3 years agoEthernet without using the Nios II
Is there an ethernet example that does not go through the Nios II processor and send and receives packets from a host computer? My assumption is that if Nios II is used then this means a C program ha...
- 3 years ago
Hi mac23,
You can use TSE MAC ethernet IP without using the NIOS II soft core. AN647 TSE IP example design also did not use Nios II.
AN647 Application note and its example designs are available at below:
zying
ZiYing_Intel
3 years agoHi mac23,
You also can find the design in the FPGA design store. For more projects, please do refer link below https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-examples/design-store.html?q=window&s=Relevancy
Zi Ying
- mac233 years ago
Could you please refer me to an ethernet design that doesn't use the Nios 2 in the FPGA design store?
Thank you for your help!
