mac23
3 years agoEthernet without using the Nios II
Is there an ethernet example that does not go through the Nios II processor and send and receives packets from a host computer? My assumption is that if Nios II is used then this means a C program ha...
- 3 years ago
Hi mac23,
You can use TSE MAC ethernet IP without using the NIOS II soft core. AN647 TSE IP example design also did not use Nios II.
AN647 Application note and its example designs are available at below:
zying
ZiYing_Intel
3 years agoHi mac23,
You may find the ethernet example design from the web page below https://www.rocketboards.org/foswiki/Main/WebHome
zying
mac23
3 years agoIt seems that the projects listed in the rocketboards.org only support Linux project. Sadly, I am not able to access Linux.
Thank you for the help! Please do let me know if you could find other projects that aren't in accessed through Linux environment.
