18 years ago
Ethernet with NiosII on Cyclone III FPGA Board?
I would like to use the ethernet on the cyclone 3c120 fpga development board with NiosII and the Niche TCP/IP stack. Anybody has done this already or knows about a quick solution? The CD of this development kit containts only a basic nios2 reference design..
Thanks for help,
Christian
    i have been researching how to hookup the TSE core to a NIOS processor for a while now. through your link to the 9.0.2 version ( i had the 7.2 version) i finally found the solution! all along, i just needed to use a Scatter-Gather DMA Controller to connect the streaming sources to the NIOS.
    unfortunately, now i have to figure out how to send and recieve UDP messages... haha. Thanks for the Information Daixiwen.
    Hello Dai -
    I did get the linux build/hjardware you sent me a link to (the one without the LCD nios) up and running the SSS example - now I am trying to get UDP running on it. I replaced SSSSimpleSocketServer() with the following... The results is that I get nothing when sending a udp packet to the board. The code is stalled in the recvfrom and it is waiting... I am using UDP tester to send to port 1024 and verifying that it is on the wire with packetmon...
    Any help would be most appreciated...
    Thanks - Chris
    void ssssimplesocketservertask()
    struct sockaddr_in serverAddr;
    int udpsock, status=0, bytes_sent=0;
    alt_u8 buf[MAX_UDP_LENGTH], id_packet=0;
    int fromlen;
    //----------- Socket Configuration --------------
    serverAddr.sin_family = AF_INET;
    serverAddr.sin_port = htons(UDP_PORT);
    serverAddr.sin_addr.s_addr = INADDR_ANY;
    fromlen = sizeof (serverAddr);
    if ((udpsock = socket(AF_INET, SOCK_DGRAM, 0)) < 0) { // protocol <IPPROTO_UDP>
    alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Socket creation failed");
    //----------- system init goes here --------------
    //------------- Main loop for task ---------------
    while(1){
    printf("listening to UDP port...\n");
    printf("serverAddr.sin_family = %08x\n", serverAddr.sin_family);
    printf("serverAddr.sin_port =%08x\n", serverAddr.sin_port);
    printf("serverAddr.sin_addr.s_addr =%08x\n", serverAddr.sin_addr.s_addr);
    printf("serverAddr =%08x\n", serverAddr);
    if((recvfrom(udpsock, buf, 10, 0,(struct sockaddr*)&serverAddr, &fromlen)) <0 )
    alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] rx UDP error");
    else
    printf("we got here\n");
    &#12288;
    printf("datagram : %s", buf);
    OK - that was dumb - I wasn't binding the socket - so now I have UDP traffic. The next question I have I'll start a new thread for as it's relating to the TSE with the dual SGDMA modules...
