18 years agoEthernet with NiosII on Cyclone III FPGA Board?
I would like to use the ethernet on the cyclone 3c120 fpga development board with NiosII and the Niche TCP/IP stack. Anybody has done this already or knows about a quick solution? The CD of this deve...
16 years agoHello Dai -
Wondering if you were able to locate your Gig-E design? The design on the nioswiki has so much extra added to it (due to using the standardized linux platform w/ 2 nios devices, lcd, etc) that it is not a useful jumping off point for people who need as much free fpga space as possible... -Chris There is no design example available and I think there will never be. You can't use the CII example because it uses a different chip. Altera really screwed up on the CIII kit, less than half the board is actually usable straight out of the box. I made a design a while ago on that kit with an Ethernet connection, but it had some restrictions (Gigabit only, need to modify the ipport.h file, etc...). I posted it a while ago on the Nios forum but can't find it now. I'll see if I can find it again. last edited by daixiwen : september 25th, 2009 at 01:40 am. http://www.alteraforum.com/forum//proweb/buttons/quote.gif (http://alteraforums.net/forum/newreply.php?do=newreply&p=73089)
