18 years agoEthernet with NiosII on Cyclone III FPGA Board?
I would like to use the ethernet on the cyclone 3c120 fpga development board with NiosII and the Niche TCP/IP stack. Anybody has done this already or knows about a quick solution? The CD of this deve...
16 years agoThis is the example of pin description in the cyclone III manual:
U5 pin 2 RGMII interface receive clock 1.8 V ENET_RX_CLK B14 U5 pin 95 RGMII interface receive data bus bit 0 2.5 V ENET_RX_D0 W8 U5 pin 92 RGMII interface receive data bus bit 1 2.5 V ENET_RX_D1 AA6 U5 pin 93 RGMII interface receive data bus bit 2 2.5 V ENET_RX_D2 W7 and for examplу of flash description: Signal Name Description I/O Standard FSM_A(24:0) Address bus (word aligned) 1.8-V LVCMOS out (25 bits) FSM_D(15:0) Data bus N/A (Accounted for in SRAM section) FLASH_CSn Chip select 1.8-V LVCMOS out FLASH_OEn Output enable 1.8-V LVCMOS out FLASH_WEn Write enable 1.8-V LVCMOS out FLASH_RSTn Reset 1.8-V LVCMOS out here we can find if it is out or in.
