18 years agoEthernet with NiosII on Cyclone III FPGA Board?
I would like to use the ethernet on the cyclone 3c120 fpga development board with NiosII and the Niche TCP/IP stack. Anybody has done this already or knows about a quick solution? The CD of this deve...
16 years agoThe example of Tse (altera\81\kits\cycloneIII_3c120_embedded\examples\standard) is working only on Quartus II above 8.0 version.
It works on 8.1 but failed on 8.0. Now i try understand where can i find the pinouts(from shematic maybe)? And i have a question - if i try 100 mbps i should use 25Mhz clock on rx and tx clocks? Where about the pins ena_10 and eth_mode, how and where should i connect them?
