18 years agoEthernet with NiosII on Cyclone III FPGA Board?
I would like to use the ethernet on the cyclone 3c120 fpga development board with NiosII and the Niche TCP/IP stack. Anybody has done this already or knows about a quick solution? The CD of this deve...
16 years agoThere is no design example available and I think there will never be. You can't use the CII example because it uses a different chip. Altera really screwed up on the CIII kit, less than half the board is actually usable straight out of the box.
I made a design a while ago on that kit with an Ethernet connection, but it had some restrictions (Gigabit only, need to modify the ipport.h file, etc...). I posted it a while ago on the Nios forum but can't find it now. I'll see if I can find it again.
