16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years ago --- Quote Start --- If you manually calculate the CRC32 on the received packet, is it ok? --- Quote End --- I think yes. The TripleSpeedEthernet receives every frame with a CRC32-Error. So I think there is a general problem in the configuration. In command_config I have set the following bits:
- TX_ENA
- RX_ENA
- ETH_SPEED
- PROMIS_EN
