16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years agoI can see two problems:
Register access: you release the write signal too soon. Try to keep it to 1 and see if waitrequest is released after a while. You should only release write when waitrequest is at 0. Packet send: the sop is never seen by the TSE because you release it before the rising edge of the clock. More generally the data is changing faster than the clock so I think that you are not generating the packet with the same clock than ff_tx_clk.
