16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years ago --- Quote Start --- This means that when you address the component yourself, you need to divide the address by four. i.e. supply "00000010" on the address bus to access the config register. --- Quote End --- OK, thank you. I didn't know this. So until now the following things work:
- Physical ethernet connection (LEDs are on)
- Programming of the TSE Register (command_config)
- Time constraints (I included the default tse_constraints.sdc, but I did nothing with timequest)
- tx_clk,rx_clk: 125 MHz without phase shift
