16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years agoI was about to suggest to put a proper reset signal generator for the PHY. The Nios example uses one (in global_reset_generator.v) that could serve that purpose.
The marvel chip is known for having reset issues on the Stratix board (it won't init properly if it didn't have a reset pulse at power up) but as far as I know the Cyclone III board doesn't have the problem. Still it is a good idea to reset properly the PHY at power up, it can't hurt ;)
