16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years agoOn the Board (near the ethernet connector) there are two Pins and next to them is a label: ENET_HSDAC.
One pin is P, the other is N. I wonder whether it's something like a jumper that I have to set in order to use the Ethernet. But maybe P means plus and M means minus, then I have a short circuit. In the data sheet these pins are not mentioned. But the PHY Chip has normal temperature (~35°C), so it seems that the PHY is working. All the LED (10,100,1000,duplex,tx,rx) are off. Do you think that the board could be damaged or something? I am working since two days on it and I still don't even get a physical connection...
