16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years ago --- Quote Start --- One of the LEDs (10 / 100 / 1000) should also be on. If its sot the case, check the signals to the PHY, especially reset_n. Maybe you are forcing the PHY in reset state... --- Quote End --- None of the LED is on. I checked the reset signal and thought I found the error: I connected port "reset" of TSE core to ENET_RESETn, so I added an inverter. But it didn't help. I can put the reset port to constant 1 or 0, it's no difference. I wonder where to connect management bus data , management bus data clock and 1000 mb link established on the TSE. When I program my time limited SOF file on the board, it says: remaining time: unlimited (which can not be because I do not have a license) I also did the timing constraints. To configure the registers (command_config) I sent the according signals to address and writedata and sent a positive edge to the write port of the TSE.
