16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years agoNo, you should have a connection. One of the LEDs (10 / 100 / 1000) should also be on. If its sot the case, check the signals to the PHY, especially reset_n. Maybe you are forcing the PHY in reset state...
