16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years agoNo it doesn't work that way. The Avalon memory mapped interface is only used to configure the registers in the mac.
You will need to set up a few registers to enable and configure the Mac. For that you supply the address and data on address and write_data, put a '1' on the write signal, and wait for waitrequest to go back to '0'. Then you can write another value. To send a packet, you need to use the Avalon stream sink ff_tx. You don't have any address there, just send your words one after the others and use the rdy/wren for flow control. Those interfaces are described in the Avalon spec.
