16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years ago --- Quote Start --- ...directly access the nios' memory --- Quote End --- I think the size of the Nios' memory is about 4 MBit. So I guess it's not the same as the ddr2-sdram on the Board... For my project, I think I am going to use Ethernet (with NIOS). My VHDL-Hardware will fill the DDR2-SDRAM with Data (received from ADC). Then the NIOS should read the DDR2-SDRAM and send the Data via Ethernet to the PC. I will take care of the speed of Ethernet later, at first I am glad if it works at all... In this case, my hardware and software are independent in a way. Could there be problems when the FPGA and the NIOS both access the DDR2-SDRAM? Thank you, Daixiwen! :)
