16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years ago --- Quote Start --- The Nios is the easiest way if you don't want to spend too much time on the project. --- Quote End --- On the one hand, I got several months to get it working but on the other hand I am still a beginner... I got another question: --- Quote Start --- Also included is a complete MAC driver to be used in conjunction with Altera's implementation of the InterNiche TCP/IP Stack. The driver and MAC have been tested with both the UCOSII and Superloop implementations of the stack. you should be able to drop it into your system and be able to run altera's simplesocket server example without problems. You may need to do a little work to support your PHY (explained in the enclosed MSWORD document). --- Quote End --- I downloaded this and put it in Quartus but I couldn't understand how to use this, even not when reading the included Guide (the DOC-File). But if it says that I should be able to run the SimpleSocket Server example, so it is not true that I need to code ARP/TCP/... by myself, because I think that this InterNiche TCP/IP Stack is doing this for me. Where can I read how to use the avalon opencores 10/100 ethernet mac and who can give me an example design with it and Cyclone III Board?
