16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years agoThe Nios is the easiest way if you don't want to spend too much time on the project.
If you need performance, the offload example given by slaker is a good way to go: you use a CPU for all the protocols that are better handled in software (ARP, TCP...) and use hardware only for specific high-speed UDP ports.
