16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years ago --- Quote Start --- The easiest way would be to use a Nios CPU and an operating system with a TCP/IP stack. --- Quote End --- OK, I understand. So I have a question about nios now: As I have read, the NIOS II is an embedded soft processor on the Board. Is it possible to write a program in C for the NIOS and use that NIOS program as a core/entity in my Quartus Block Diagram/Schematic File? To get a fast speed I want to use mainly VHDL. But if Ethernet is that difficult with VHDL, I could maybe use the NIOS. I have attached two Images so you can see what I am doing.
