16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years agoThis is the Altera Triple Speed Ethernet, available in SOPC builder, or seperately from the MegaWizard in Quartus. But I thought you found it, according to your first post.
I don't know what you mean by "best", it depends on your needs and resources. The easiest way would be to use a Nios CPU and an operating system with a TCP/IP stack. Without the Nios you'll need to code at least the ARP and UDP/IP protocols in hardware.
