16 years agoEthernet with DSP Dev. Kit Cyclone III (no NIOS)
Hi, I have the dsp development kit, cyclone iii edition (http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html). How can I use the Ethernet? In my altera > 80 > ip Direct...
16 years ago --- Quote Start --- Yes you need to use that interface to send your Ethernet packets. It is rather simple to use. --- Quote End --- But it is only for unidirectional communication: --- Quote Start --- You can use Avalon Streaming (Avalon-ST) interfaces for components that drive high bandwidth, low latency, unidirectional data. --- Quote End --- (Source: http://www.altera.com/literature/manual/mnl_avalon_spec.pdf) Is there also something for bidirectional data?
