Ethernet PHY Attachment Issue on Cyclone V SoC Board
Hi Nitin,
So, both HPS ethernet are used together and both are with the HPS IO's.
Did you tried disabling 2nd HPS ethernet(working) and used only 1st ethernet(non-working)?
Also, can try with below line in ethernet@ff700000.
altr,sysmgr-syscon = <0x20 0x60 0x02>; //also try and check with commenting this line
phy-mode = "rgmii-id";
Tiwari
Yes, both PHYs are on HPS, and I have checked with the second Ethernet (working) disabled. Additionally, I have tried the changes you suggested:
altr,sysmgr-syscon = <0x20 0x60 0x02>; // also tried commenting this line
and
However, the issue remains the same. Below are the relevant logs related to Ethernet:
[ 1.564121] socfpga-dwmac ff700000.ethernet: IRQ eth_wake_irq not found
[ 1.570748] socfpga-dwmac ff700000.ethernet: IRQ eth_lpi not found
[ 1.577034] socfpga-dwmac ff700000.ethernet: PTP uses main clock
[ 1.583210] socfpga-dwmac ff700000.ethernet: Version ID not available
[ 1.589652] socfpga-dwmac ff700000.ethernet: DWMAC1000
[ 1.594861] socfpga-dwmac ff700000.ethernet: DMA HW capability register supported
[ 1.602324] socfpga-dwmac ff700000.ethernet: RX Checksum Offload Engine supported
[ 1.609786] socfpga-dwmac ff700000.ethernet: COE Type 2
[ 1.614993] socfpga-dwmac ff700000.ethernet: TX Checksum insertion supported
[ 1.622030] socfpga-dwmac ff700000.ethernet: Enhanced/Alternate descriptors
[ 1.628981] socfpga-dwmac ff700000.ethernet: Extended descriptors not supported
[ 1.636270] socfpga-dwmac ff700000.ethernet: Ring mode enabled
[ 1.642101] socfpga-dwmac ff700000.ethernet: device MAC address a2:de:14:70:1c:cc
[ 1.668634] mdio_bus stmmac-0:00: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 1.678136] mdio_bus stmmac-0:01: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[ 1.687617] mdio_bus stmmac-0:02: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:02, irq=POLL)
[ 1.697075] mdio_bus stmmac-0:03: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:03, irq=POLL)
[ 1.706529] mdio_bus stmmac-0:04: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:04, irq=POLL)
[ 1.715983] mdio_bus stmmac-0:05: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:05, irq=POLL)
[ 1.725427] mdio_bus stmmac-0:06: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:06, irq=POLL)
[ 1.734880] mdio_bus stmmac-0:07: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:07, irq=POLL)
[ 1.744334] mdio_bus stmmac-0:08: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:08, irq=POLL)
[ 1.753788] mdio_bus stmmac-0:09: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:09, irq=POLL)
[ 1.763242] mdio_bus stmmac-0:0a: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:0a, irq=POLL)
[ 1.772695] mdio_bus stmmac-0:0b: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:0b, irq=POLL)
[ 1.782149] mdio_bus stmmac-0:0c: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:0c, irq=POLL)
[ 1.791602] mdio_bus stmmac-0:0d: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:0d, irq=POLL)
[ 1.801055] mdio_bus stmmac-0:0e: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:0e, irq=POLL)
[ 1.810509] mdio_bus stmmac-0:0f: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:0f, irq=POLL)
[ 1.819962] mdio_bus stmmac-0:10: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:10, irq=POLL)
[ 1.829416] mdio_bus stmmac-0:11: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:11, irq=POLL)
[ 1.838870] mdio_bus stmmac-0:12: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:12, irq=POLL)
[ 1.848324] mdio_bus stmmac-0:13: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:13, irq=POLL)
[ 1.857778] mdio_bus stmmac-0:14: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:14, irq=POLL)
[ 1.867231] mdio_bus stmmac-0:15: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:15, irq=POLL)
[ 1.876684] mdio_bus stmmac-0:16: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:16, irq=POLL)
[ 1.886137] mdio_bus stmmac-0:17: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:17, irq=POLL)
[ 1.895580] mdio_bus stmmac-0:18: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:18, irq=POLL)
[ 1.905032] mdio_bus stmmac-0:19: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:19, irq=POLL)
[ 1.914487] mdio_bus stmmac-0:1a: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:1a, irq=POLL)
[ 1.923940] mdio_bus stmmac-0:1b: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:1b, irq=POLL)
[ 1.933392] mdio_bus stmmac-0:1c: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:1c, irq=POLL)
[ 1.942847] mdio_bus stmmac-0:1d: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:1d, irq=POLL)
[ 1.952299] mdio_bus stmmac-0:1e: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:1e, irq=POLL)
[ 1.961752] mdio_bus stmmac-0:1f: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:1f, irq=POLL)
[ 1.973049] dwc2 ffb40000.usb: supply vusb_d not found, using dummy regulator
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ 9.542391] socfpga-dwmac ff700000.ethernet eth0: validation of rgmii with support 0000000,00000000,00006280 and advertise2
[ OK ] Reached target Network.
[ 9.596027] socfpga-dwmac ff700000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -22)
Starting Run init_all.sh script...
[ 9.630811] socfpga-dwmac ff700000.ethernet eth0: validation of rgmii with support 0000000,00000000,00006280 and advertise2
[ 9.706421] socfpga-dwmac ff700000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -22)
[ 9.724555] socfpga-dwmac ff700000.ethernet eth0: validation of rgmii with support 0000000,00000000,00006280 and advertise2
Starting Hostname Service...
Starting WPA supplicant...
[ OK ] Started User Login Management.
[ 9.799816] socfpga-dwmac ff700000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -22)
[ OK ] Finished Run init_all.sh script.
eht1 is disabled
