Errors in build GSRD for Agilex 7 F-Series Transceiver-SoC DevKit
Hi Marco,
Can you try to recompile at your side. se i manage t compile it.
I dont do anything i the code. I seem updated during running below
cd agilex_gsrd
export TOP_FOLDER=$(pwd)
export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu/bin:$PATH
export ARCH=arm64
export CROSS_COMPILE=aarch64-none-linux-gnu-
sudo ln -sf /bin/bash /bin/sh
cd $TOP_FOLDER
cd gsrd_socfpga
. agilex7_dk_si_agf014ea-gsrd-build.sh
build_setup
cd $TOP_FOLDER/gsrd_socfpga
. ./poky/oe-init-build-env agilex-gsrd-rootfs/
bitbake_image
- Saathvik1 year ago
I am doing it by the same steps done by you
I am getting this error.Plz helpERROR: OE-core's config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:The TMPDIR: /g/workarea/xsaathvik/quartus_proj/agilex_gsrd/gsrd_socfpga/agilex-gsrd-rootfs/tmp can't be located on nfs.
