Ppavan's avatar
Ppavan
5 years ago
Error(20072): Incorrect VID settings
I see the following errors while programming the Stratix 10 MX board :
1. Error(18950): Device has stopped receiving configuration data
2. Error(18948): Error message received from device: Detected hardware access error. There is a failure in accessing external hardware. (Subcode 0x0032, Info 0x00000000, Location 0x0000B400)
3. Error(20072): A PMBUS error has occurred during configuration. Potential errors: Incorrect VID setting in Quartus Project. The target device fails to communicate to smart regulator or PMBUS Master on board.
4. Error(209012): Operation failed
I am using Quartus 19.2 Prime Pro version. The device ID is 1SM21BHU2F53E2VGS1.
I checked multiple places online. I have tried adding extra power management settings in the qsf file, but none of them worked. Kindly help me in resolving this issue.
Thank you.
    • Ppavan's avatar
      Ppavan
      Hi Aiman,
      I have already tried the solution you shared.
      The same error still exists.
      Pavan
  • Hi Pavan,
    The error occur due to VID setting.
    To have the correct setting please refer to the checklist here:
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/support/devices/SmartVID/Smart-VID-Checklist.pdf
    I tis very crucial to check and confirm the first to line in the QSF file:
    set_global_assignment -name USE_PWRMGT_SDA SDM_IO11
    set_global_assignment -name USE_PWRMGT_SCL SDM_IO14
    Please confirm the correct pin is connecting to your hardware. The SDM_IO pin is depending on your pin setting.
    It can be IO1- IO16.
    Please ensure the pin is set accordingly to your connection.
    Aiman
    • Ppavan's avatar
      Ppavan
      The problem has been resolved and now we are able to program the device.
      Thank you very much for the help.
  • I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
