Ppavan
4 years agoError(20072): Incorrect VID settings
I see the following errors while programming the Stratix 10 MX board :
1. Error(18950): Device has stopped receiving configuration data
2. Error(18948): Error message received from device...
NurAiman_M_Intel
4 years agoHi Pavan,
The error occur due to VID setting.
To have the correct setting please refer to the checklist here:
I tis very crucial to check and confirm the first to line in the QSF file:
set_global_assignment -name USE_PWRMGT_SDA SDM_IO11
set_global_assignment -name USE_PWRMGT_SCL SDM_IO14
Please confirm the correct pin is connecting to your hardware. The SDM_IO pin is depending on your pin setting.
It can be IO1- IO16.
Please ensure the pin is set accordingly to your connection.
Aiman
Ppavan
4 years agoHi,
The problem has been resolved and now we are able to program the device.
Thank you very much for the help.
