Error with "quartus_sh" command after interface planner
- 3 years ago
Have you set your PATH environment variable to the bin directory of your quartus? Try this and then re-run
Considering you're using Linux:
export PATH=$PATH:<installed_quartus_directory>/<version>/quartus/bin
On Window
1) Open up your command prompt (cmd)
2) Type set PATH=%PATH%;C:\altera\12.1\quartus\bin
Change the back party of the PATH after ';' according to your quartus installation directory
Then try to run quartus_sh again
Similar issue found out that might be helping.
On Window
- Junyong3 years ago
Hi SyafieqS,
Thank you for your reply.
I could run the generated tcl file with the following add-on window.
Thank you for your help.
Junyong
